WLC Max Throughput
ZK916
Level 3
Level 3
I could not find any clear explanation related to the max throughput associated with the C9800-L WLC.
The datasheet (link below) says that the base max throughput is 5Gbps and with the boost license is 10Gbps.
I wanted some clarification as to whether this base max throughput relates to the max ingress and egress packets that all interfaces can handle or relates to the max throughput that the CPU can handle?
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/datasheet-c78-742434.html
Thanks in advance.
~zK
6 Replies 6
Mark Elsen
    - This table below seems to confirm your figures : as far as your statement concerning the CPU ; these devices are more complex then that , and probably the core cpu doesn't even care as those limits are related to other components (too) ; such as network interfaces and switching infrastructure  beyond that
  - Added info : https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/nb-06-cat9800-ser-wirel-faq-ctp-en.html
Table 1.           Cisco Catalyst 9800 Series Wireless Controller appliances scale and performance
Product
Number of access points
Number of clients
Throughput
9800-L
250
5000
Up to 5 Gbps
9800-L with performance license
500
10,000
Up to 9 Gbps
9800-40
2000
32,000
Up to 40 Gbps
9800-80
6000
64,000
Up to 80 Gbps
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
Maximum Throughput that box can handle.
BB
Thanks for your input.
I find it interesting that this particular platform supports 250 WAPs and up to 5000 clients but can only process 5Gbps with the base license.
Best, ~sK
Correct you need to plan correctly looking at the Future model.
It also depends on the deployment method. if you doing CAPWAP / Flex - then all the traffic go via WLC
if you deploy different switching method, Only Control Traffic go via WLC.
BB
This comes back to data that has been collected through the years.  There were large organizations that would only use a single 1 gig link with no issues, so seeing a 5GHz limit for base I would say is fine.  I knew a few large customers that only used 1 Gig links on a 5508 with more than 250 ap's.  I didn't suggest that, but that is what they did.
-Scott
Leo Laohoo
Take the "recommended" number of APs with extreme caution.
I've just been told "ideal" AP load condition of a 9800-80 to be 4800 (or 80%).  If this is the load condition of a monster 9800-80 then treat the same to the "baby" WLC.
