Apple iOS device connection issues
Greg Dickinson
Level 2
Level 2
I have a 2504 WLC with 3502 (and one 1311) APs.  I'm advertising three networks using local switching, to drop the traffic onto separate VLANs at each site.  We use the controller for configuration and AAA authentication, against a Server 2008 server running NPS.  I have a single user with a few Apple devices that seemingly at random loses connection to the wireless network.  When he loses connection I see the following in the event log on the WLC:
2Wed Aug  7 16:14:58 2013AAA Authentication Failure for UserName:[user]  User Type: WLAN USER
3Wed Aug  7 16:14:58 2013AAA Authentication Failure for UserName:
[user]
4Wed Aug  7 16:14:58 2013 AAA Authentication Failure for UserName:
[user]
Over and over, several times a second.  However I don't see these requests at the NPS server, and his AD account does not lock out as I would expect after several attempts to log in.  This account is used for wireless access and has a non-expiring password.
It seems to just be Apple devices - this user and one other have this issue and  both use iPads and iPhones.  Any clue what might be going on?
That looks fine. I would just make sure session timeout is disabled and load balancing is disabled on the advanced tab.
-Scott
7 Replies 7
Scott Fella
Check your encryption being used. You should only use either WPA v1 with TKIP or WPA v2 with AES. Don't mix and match and don't enable both on the same SSID.
-Scott
I'm pretty sure that's how it's set up (I'll admit I'm not the wireless expert...) Here's what I have:
Message was edited by: Greg Dickinson - Image was missing
-Scott
OK the timeout was enabled on both the "Corporate" and "BYOD" WLANS, so I disabled it there.  I left it enabled on the "Guest" WLAN that uses lcoal webauth.  Let's see what happens.
Thanks for the help.
Scott Fella
If your using WebAuth then you still want to disable session timeout or maybe set it to 28800 sec and still set your idle timer to 7200 for example. Apple devices if the login and then goes to sleep will be required to login every time which isn't ideal.
-Scott
The timeout settings seems to have fixed the issue.  Thanks Scott...
Of course now I have some other questions regarding finding a host that keeps spamming the AAA server, but that's another subject for another thread
Well glad it's working for you.
-Scott
