Application Visibility And Control Bittorrent
Maddin B
I can use the Application Visibility And Control does not block the traffic from Bittorrent? Or have I misunderstood?
However, I have on my WLC 2504 that configures goes Bittorrent still.
luckymike33
Have you checked whether you have applied this to a WLAN - go to WLANS -> WLAN ID ->look at AVC profile.
Have a look at this document here
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/115756-avc-guide-00.html
Mike
luckymike33
Mike
Thanks, this was my problem!
Naveen Kumar
Level 4
Level 4
Here is the protocol list supported in NBAR2
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6558/ps6616/product_bulletin_c25-627831.html
I can see "bittorrent", "encrypted-bittorrent", "bittorrent-networking" as recognised protocol in the list, but nothing for utorrent.
From WLC code 7.5 onwards you can update these protocol packs on your controller (see below for more detail)
http://www.cisco.com/en/US/docs/wireless/controller/technotes/7.5/AVC_dg7point5.html
Protocol pack 4.1.1 is the latest for 7.5 code. Here is the more information about it.
http://www.cisco.com/en/US/docs/wireless/controller/nbar2_prot_pack/4.1.1/b_nbar2_prot_pack_411.html
Latest protocol pack (pp-AIR-7.6-13-6.3.0.pack) is available for 7.6 code version if you would like to test it out.
@ nkumarsr The protocol pack is not compatible with WLC 2504 or?
