appltv remote is not working on cisco 9800
mmercald
I am have 2 9800s in a Foreign and Anchor setup.  Currently I have multicast setup on the Foreign and MDNS gateway setup on the anchor.  Currently the appletv are connected to the ATV ssid.  If I have an iphone or ipad connected to the ATV ssid, airplay works however the appletv remote app does not list any of the tvs.  What should I do to get this working?
@mmercald
 Without have any further knowledge of your environment or seeing any logs, I would recommend you to double check the config based on this guide.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215352-configure-and-troubleshoot-mdns-on-catal.pdf
and make sure you dont have "Peer-to-peer blocking"  enable on the SSID.
