APs lose connection and WLC 5500 series
Menezor
All the APs lose connection from WLC 5500 and I dont know why and the config is good???
6 Replies 6
marce1000
             - Check controller logs when that happens ,
M.
No saved log is found except the current log records
Leo Laohoo
Rich R
Seriously @Menezor your post is rather lacking in detail!
What models of APs?
What version of software?
Did something happen that triggered this? (eg WLC reloaded, APs lost connectivity to WLC etc)
What do the AP console logs show?
What do the WLC logs show?
What method are you using for your APs to discover the WLC? (same LAN, helper address, DNS, DHCP option 43)
And meanwhile take a look at the field notice for certificates below.  If it's that then you need to follow ALL the steps in the field notice to resolve the issue permanently. I'll summarise as I have done many times before in this community which you would have found if you had searched:
1. Upgrade to the latest version which supports your APs and WLC - probably 8.5.182.0
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc10
2. Apply the config workaround on the WLC
3. Disable WLC NTP and set time manually to before your certs expired
4. Allow all the APs to join, download new code, pick up the config workaround
5 Re-enable NTP
Note that it could be AP and/or WLC certs which have expired.
Hello Rich.
What models of APs? the APs are AP1130AG model
What version of software? The WLC 5508 software model is 7.0.220.0 Release
Did something happen that triggered this? Power fluctuations and ISP downtime for some weeks were the recent happenings
What do the WLC logs show? Just the current logs are showing no old logs
         - FYI : https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
 M.
