04-01-2004 07:44 AM - edited 07-04-2021 09:29 AM
1/ I am trying to run some APs radio scan on the WLSE 2.5/AP1200(12.2(11)JA1) but no way.. Once I launch the job, I have a failure with a log:
INFO: Executing the AP Radio Scan
INFO: Max Tx Power 100mW
INFO: Number of devices selected to participate in AP Scanning: 3
WARNING: Skipping device AP1200_03 because it is not registered with any WDS
WARNING: Skipping device AP1200_01 because it does not run required software
WARNING: Skipping device AP1200_02 because it does not run required software
ERROR: Aborting execution of AP Scanning task because there are no applicable Radio Interfaces that can participate.
Any help, will be great.
04-01-2004 11:32 AM
For all Radio Management feature in WLSE 2.5 to work, the following must be setup/met before you can use it:
a) The AP must be running IOS 12.2(13)JA or later. The version that you're running will not work.
b) WDS must be setup first properly, WDS AP must be authenticated with WLSE and all APs must be managed by the WLSE as well.
c) Currently, Radio Management features only support 'b' radios. a/g support is coming in the next release.
04-02-2004 05:55 AM
Hi again,
WLSE 2.5 offers a number of toolkits and features for radio management including :
- Radio Manager
- AP Radio Scan
- Client Walkabout
- Location Manager
- RM Assisted Configuration
- Manage RM Measurements
On the Help/Documentation of WLSE, I can not see what are the requirements of each feature (AP IOS ?, WDS or not ? etc).
Can some one give any help for this issue : URL s? Links ? or direct answer ?
Thanks in advance.
- Here an example of a a radio scan I have lanched :
- Here is an example of Walkabout :
No Location Information available for the current selection. Client Walkabout Location Information is available only for the recently completed Client Walkabout Job
