APs register on WLC, but do not join group.
Kyle Gatlin
Just a quick question. When configuring ports facing the WLC, the port facing the WLC management should be switch access vlan management with trunks for the SSIDs, correct?
Ports facing APs should be native management vlan and allowed ssid vlans, correct?
I'm seeing APs hit the WLC but not joining any network. Show ap join stats detailed either shows "not applicable" across the board or "discovery requested decoding with subnet broadcast and wrong ap ip address" but I'm not sure where I can look to fix that.
Have to do most of this via CLI for the time being as it is a remote site.
Trunks off the switches have the same vlans all trunked to my linux box which acts as DHCP and DNS.
How can I make sure that WLAN interfaces are associated with the correct SSID and VLAN?
The CLI in this thing is so so so obtuse.
Management interface is on the 172.24.0.0 /24 subnet.  Our DHCP service on the same VLAN hands out 192.168.0.0/24 IPs.
Debug
*spamApTask0: Aug 24 22:18:53.530: cc:d8:c1:22:23:50 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.50:8758
*spamApTask0: Aug 24 22:18:53.530: cc:d8:c1:22:23:58 Failed to parse CAPWAP packet from 192.168.0.50:8758
*spamApTask0: Aug 24 22:18:53.531: cc:d8:c1:22:23:50 ApModel: AIR-CAP702W-A-K99
*spamApTask0: Aug 24 22:18:53.531: cc:d8:c1:22:23:50 Received a Discovery Request from CC:D8:C1:22:23:50 via IP broadcast address but the source IP address (192.168.0.50) is not in any of the configured subnets. Dropping it
*spamApTask0: Aug 24 22:18:53.531: cc:d8:c1:22:23:50 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.50:8758
*spamApTask0: Aug 24 22:18:53.531: cc:d8:c1:22:23:58 Failed to parse CAPWAP packet from 192.168.0.50:8758
*spamApTask0: Aug 24 22:18:53.531: Unknown AP type. Using Controller Version!!!
*spamApTask7: Aug 24 22:18:53.631: cc:d8:c1:22:3f:d0 ApModel: AIR-CAP702W-A-K99
*spamApTask7: Aug 24 22:18:53.631: Unknown AP type. Using Controller Version!!!
*spamApTask7: Aug 24 22:18:53.854: cc:d8:c1:22:22:40 ApModel: AIR-CAP702W-A-K99
*spamApTask7: Aug 24 22:18:53.854: Unknown AP type. Using Controller Version!!!
*spamApTask1: Aug 24 22:18:53.892: cc:d8:c1:22:44:d0 ApModel: AIR-CAP702W-A-K99
*spamApTask1: Aug 24 22:18:53.893: cc:d8:c1:22:44:d0 Received a Discovery Request from CC:D8:C1:22:44:D0 via IP broadcast address but the source IP address (192.168.0.27) is not in any of the configured subnets. Dropping it
*spamApTask1: Aug 24 22:18:53.893: cc:d8:c1:22:44:d0 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.27:9294
*spamApTask1: Aug 24 22:18:53.893: cc:d8:c1:22:44:d8 Failed to parse CAPWAP packet from 192.168.0.27:9294
*spamApTask1: Aug 24 22:18:53.894: cc:d8:c1:22:44:d0 ApModel: AIR-CAP702W-A-K99
*spamApTask1: Aug 24 22:18:53.894: cc:d8:c1:22:44:d0 Received a Discovery Request from CC:D8:C1:22:44:D0 via IP broadcast address but the source IP address (192.168.0.27) is not in any of the configured subnets. Dropping it
*spamApTask1: Aug 24 22:18:53.894: cc:d8:c1:22:44:d0 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.27:9294
*spamApTask1: Aug 24 22:18:53.894: cc:d8:c1:22:44:d8 Failed to parse CAPWAP packet from 192.168.0.27:9294
*spamApTask1: Aug 24 22:18:53.894: Unknown AP type. Using Controller Version!!!
*spamApTask4: Aug 24 22:18:53.972: cc:d8:c1:22:23:40 ApModel: AIR-CAP702W-A-K9
*spamApTask4: Aug 24 22:18:53.973: cc:d8:c1:22:23:40 Received a Discovery Request from CC:D8:C1:22:23:40 via IP broadcast address but the source IP address (192.168.0.47) is not in any of the configured subnets. Dropping it
*spamApTask4: Aug 24 22:18:53.973: cc:d8:c1:22:23:40 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.47:8757
*spamApTask4: Aug 24 22:18:53.973: cc:d8:c1:22:23:40 Failed to parse CAPWAP packet from 192.168.0.47:8757
*spamApTask4: Aug 24 22:18:53.974: cc:d8:c1:22:23:40 ApModel: AIR-CAP702W-A-K9
*spamApTask4: Aug 24 22:18:53.974: cc:d8:c1:22:23:40 Received a Discovery Request from CC:D8:C1:22:23:40 via IP broadcast address but the source IP address (192.168.0.47) is not in any of the configured subnets. Dropping it
*spamApTask4: Aug 24 22:18:53.974: cc:d8:c1:22:23:40 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.47:8757
*spamApTask4: Aug 24 22:18:53.974: cc:d8:c1:22:23:40 Failed to parse CAPWAP packet from 192.168.0.47:8757
*spamApTask4: Aug 24 22:18:53.974: Unknown AP type. Using Controller Version!!!
*spamApTask4: Aug 24 22:18:54.023: cc:d8:c1:22:22:60 ApModel: AIR-CAP702W-A-K9
*spamApTask4: Aug 24 22:18:54.023: cc:d8:c1:22:22:60 Received a Discovery Request from CC:D8:C1:22:22:60 via IP broadcast address but the source IP address (192.168.0.29) is not in any of the configured subnets. Dropping it
*spamApTask4: Aug 24 22:18:54.023: cc:d8:c1:22:22:60 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.29:8743
*spamApTask4: Aug 24 22:18:54.023: cc:d8:c1:22:22:60 Failed to parse CAPWAP packet from 192.168.0.29:8743
*spamApTask1: Aug 24 22:18:54.074: cc:d8:c1:22:1a:90 ApModel: AIR-CAP702W-A-K99
*spamApTask1: Aug 24 22:18:54.074: cc:d8:c1:22:1a:90 Received a Discovery Request from CC:D8:C1:22:1A:90 via IP broadcast address but the source IP address (192.168.0.55) is not in any of the configured subnets. Dropping it
*spamApTask1: Aug 24 22:18:54.074: cc:d8:c1:22:1a:90 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.55:8618
*spamApTask1: Aug 24 22:18:54.074: cc:d8:c1:22:1a:98 Failed to parse CAPWAP packet from 192.168.0.55:8618
*spamApTask1: Aug 24 22:18:54.075: cc:d8:c1:22:1a:90 ApModel: AIR-CAP702W-A-K99
*spamApTask1: Aug 24 22:18:54.075: cc:d8:c1:22:1a:90 Received a Discovery Request from CC:D8:C1:22:1A:90 via IP broadcast address but the source IP address (192.168.0.55) is not in any of the configured subnets. Dropping it
*spamApTask1: Aug 24 22:18:54.076: cc:d8:c1:22:1a:90 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.55:8618
*spamApTask1: Aug 24 22:18:54.076: cc:d8:c1:22:1a:98 Failed to parse CAPWAP packet from 192.168.0.55:8618
*spamApTask1: Aug 24 22:18:54.076: cc:d8:c1:22:1a:90 ApModel: AIR-CAP702W-A-K99
*spamApTask1: Aug 24 22:18:54.076: Unknown AP type. Using Controller Version!!!
*spamApTask7: Aug 24 22:18:54.798: cc:d8:c1:22:22:70 ApModel: AIR-CAP702W-A-K99
*spamApTask7: Aug 24 22:18:54.798: Unknown AP type. Using Controller Version!!!
*spamApTask5: Aug 24 22:18:54.922: cc:d8:c1:22:41:00 ApModel: AIR-CAP702W-A-K99
*spamApTask5: Aug 24 22:18:54.922: Unknown AP type. Using Controller Version!!!
*spamApTask2: Aug 24 22:18:55.357: cc:d8:c1:22:45:f0 ApModel: AIR-CAP702W-A-K99
*spamApTask2: Aug 24 22:18:55.357: Unknown AP type. Using Controller Version!!!
*spamApTask6: Aug 24 22:18:55.438: cc:d8:c1:22:3d:d0 ApModel: AIR-CAP702W-A-K99
*spamApTask6: Aug 24 22:18:55.438: cc:d8:c1:22:3d:d0 Received a Discovery Request from CC:D8:C1:22:3D:D0 via IP broadcast address but the source IP address (192.168.0.8) is not in any of the configured subnets. Dropping it
*spamApTask6: Aug 24 22:18:55.438: cc:d8:c1:22:3d:d0 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.8:9182
*spamApTask6: Aug 24 22:18:55.438: cc:d8:c1:22:3d:d0 Failed to parse CAPWAP packet from 192.168.0.8:9182
*spamApTask0: Aug 24 22:18:55.533: cc:d8:c1:22:22:80 ApModel: AIR-CAP702W-A-K99
*spamApTask0: Aug 24 22:18:55.533: cc:d8:c1:22:22:80 Received a Discovery Request from CC:D8:C1:22:22:80 via IP broadcast address but the source IP address (192.168.0.15) is not in any of the configured subnets. Dropping it
*spamApTask0: Aug 24 22:18:55.533: cc:d8:c1:22:22:80 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.15:8745
*spamApTask0: Aug 24 22:18:55.533: cc:d8:c1:22:22:80 Failed to parse CAPWAP packet from 192.168.0.15:8745
*spamApTask0: Aug 24 22:18:55.534: cc:d8:c1:22:22:80 ApModel: AIR-CAP702W-A-K99
*spamApTask0: Aug 24 22:18:55.534: cc:d8:c1:22:22:80 Received a Discovery Request from CC:D8:C1:22:22:80 via IP broadcast address but the source IP address (192.168.0.15) is not in any of the configured subnets. Dropping it
*spamApTask0: Aug 24 22:18:55.535: cc:d8:c1:22:22:80 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.15:8745
*spamApTask0: Aug 24 22:18:55.535: cc:d8:c1:22:22:80 Failed to parse CAPWAP packet from 192.168.0.15:8745
*spamApTask0: Aug 24 22:18:55.535: cc:d8:c1:22:22:80 ApModel: AIR-CAP702W-A-K99
*spamApTask0: Aug 24 22:18:55.536: Unknown AP type. Using Controller Version!!!
*spamApTask2: Aug 24 22:18:55.733: cc:d8:c1:22:1f:d0 ApModel: AIR-CAP702W-A-K99
*spamApTask2: Aug 24 22:18:55.733: cc:d8:c1:22:1f:d0 Received a Discovery Request from CC:D8:C1:22:1F:D0 via IP broadcast address but the source IP address (192.168.0.12) is not in any of the configured subnets. Dropping it
*spamApTask2: Aug 24 22:18:55.733: cc:d8:c1:22:1f:d0 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.12:8702
*spamApTask2: Aug 24 22:18:55.733: cc:d8:c1:22:1f:d0 Failed to parse CAPWAP packet from 192.168.0.12:8702
*spamApTask2: Aug 24 22:18:55.734: cc:d8:c1:22:1f:d0 ApModel: AIR-CAP702W-A-K99
*spamApTask2: Aug 24 22:18:55.734: cc:d8:c1:22:1f:d0 Received a Discovery Request from CC:D8:C1:22:1F:D0 via IP broadcast address but the source IP address (192.168.0.12) is not in any of the configured subnets. Dropping it
*spamApTask2: Aug 24 22:18:55.735: cc:d8:c1:22:1f:d0 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.12:8702
*spamApTask2: Aug 24 22:18:55.735: cc:d8:c1:22:1f:d0 Failed to parse CAPWAP packet from 192.168.0.12:8702
*spamApTask2: Aug 24 22:18:55.735: cc:d8:c1:22:1f:d0 ApModel: AIR-CAP702W-A-K99
*spamApTask2: Aug 24 22:18:55.735: Unknown AP type. Using Controller Version!!!
*spamApTask6: Aug 24 22:18:56.050: cc:d8:c1:22:23:80 ApModel: AIR-CAP702W-A-K99
*spamApTask6: Aug 24 22:18:56.050: Unknown AP type. Using Controller Version!!!
*spamApTask1: Aug 24 22:18:56.474: cc:d8:c1:22:0c:b0 ApModel: AIR-CAP702W-A-K99
*spamApTask1: Aug 24 22:18:56.474: Unknown AP type. Using Controller Version!!!
*spamApTask7: Aug 24 22:18:56.494: 34:62:88:66:18:50 ApModel: AIR-CAP702W-A-K99
*spamApTask7: Aug 24 22:18:56.494: Unknown AP type. Using Controller Version!!!
*spamApTask7: Aug 24 22:18:56.543: cc:d8:c1:22:42:10 ApModel: AIR-CAP702W-A-K99
*spamApTask7: Aug 24 22:18:56.544: cc:d8:c1:22:42:10 Received a Discovery Request from CC:D8:C1:22:42:10 via IP broadcast address but the source IP address (192.168.0.13) is not in any of the configured subnets. Dropping it
*spamApTask7: Aug 24 22:18:56.544: cc:d8:c1:22:42:10 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.13:9250
*spamApTask7: Aug 24 22:18:56.544: cc:d8:c1:22:42:10 Failed to parse CAPWAP packet from 192.168.0.13:9250
*spamApTask7: Aug 24 22:18:56.545: cc:d8:c1:22:42:10 ApModel: AIR-CAP702W-A-K99
*spamApTask7: Aug 24 22:18:56.545: cc:d8:c1:22:42:10 Received a Discovery Request from CC:D8:C1:22:42:10 via IP broadcast address but the source IP address (192.168.0.13) is not in any of the configured subnets. Dropping it
*spamApTask7: Aug 24 22:18:56.545: cc:d8:c1:22:42:10 State machine handler: Failed to process  msg type = 1 state = 0 from 192.168.0.13:9250
Sandeep Choudhary
Hi Kyle,
1. You need at-least 7.6.120.0 version or higher on WLC to join this Access Point.
2. Make sure the time is set properly on the WLC
if still fail then please paste the output of these commands:
sh version from AP
Sh sysinfo from WLC
Don't forget to rate helpful posts
ajc
Level 7
Level 7
Tested multiple times, 702W AP's require version 8 minimum. There is something else that have to be configured regarding trunk on AP702W, let me check that and post it.
