Archive feature not enabled
servisturk
Level 2
Level 2
still fighting 1552e and   is that normal? if not how can i enable it?
ap#archive config
Scott Fella
What are you trying to do?
-Scott
Hi Scott. I know that this is a very old post but I have also run into the same problem when trying the "archive config" command (I receive a response returned "archive feature not enabled"). I want to set my switch to do scheduled backups to an ftp server on my network (Catalyst 2960-x switch). Is this feature not available on this series of switch and if it is, how do I enable this feature? Your assistance will be appreciated.
muhammk2
Level 2
Level 2
Could you please elaborate your question further?
Saurav Lodh
Level 11
Level 11
Are you trying to use archieve command { router (config )# archieve } to save configuration just like a router ?
