Propagation distance difference between AIR-ANT2566D4M-R & AIR-ANT2566P4W-R
Muhammed Adnan
Level 4
Level 4
Hello Experts,
AIR-ANT2566P4W-R for being having greater azimuth and elevation compared to AIR-ANT2566D4M-R should have comparatively larger coverage cell. However as the gain is same on these two antennas(6dBi), will using AIR-ANT2566D4M-R gives some advantages in providing longer RF propagation distance as compared to AIR-ANT2566P4W-R?
My requirement is to have these antennas mounted on poles exceeding 30 meters and interested in knowing what could better translate into my requrement?
AIR-ANT2566D4M-R versus AIR-ANT2566P4W-RAIR-ANT2566D4M-R versus AIR-ANT2566P4W-R
Hi @Muhammed Adnan
You are right.
The best option depends on the users density. For higher density more focused antenna is better, however, you need more AP. If you environment is slightly density them you can spread the signal a bit more then using less APs.
  Above all, perform a detailed site survey and keep in mind that not only the antenna need to get on the floor but mobile also needs to get on the antenna.
-If I helped you somehow, please, rate it as useful.-
Step
Is the any difference of polarization?
Polarization
Linear, vertical
in P4W
vs
Vertical
Horizontal
in D4M
