Are output errors normal on Dot11 interface?
9tgonzalez
Level 2
Level 2
I have two AIR-AP1231G-A-K9 access points at 12.2(15). I’m getting about a 5% output error rate on my dot11 interface (802.11g). Is this normal?
Thanks.
Not applicable
Check if you are hitting the bug CSCec47635.
Doesn't release 12.2(15)JA resolve that?
I have 12.2(15)JA and have the same outgoing Dot11 errors on occasion. My radios will unexpectedly lock-up or reboot themselves unexpectedly too. Meanwhile, my VxWorks radios keep humming along. It's a real bummer.
