Are Users Connecting With 802.11AC?
Alex Pfeil
Level 7
Level 7
Is there an easy way to determine if clients are connecting via 802.11AC?
Sandeep Choudhary
Open a web browse and enter the IP address of the WLC. This will bring you to the Dashboard.
On the left-hand side, choose Client.
Find the client you want and click the wireless client. This will bring you to the Client View.
Under General, under client properties you should see the Current TxRateSet.
or
Under General, under AP properties you should see the AP Type.
If you look down under " Current TxRateSet", see that number. This will tell you, about the client's wireless capabilities.
If you look down under " AP type ", see that Client capabilities(eith 802.1an/bn/ac or 802.11a/b/g).
More info:
https://mrncciew.com/2014/01/10/802-11ac-with-cisco-3700-ap/
https://community.cisco.com/t5/wireless-mobility-documents/how-to-interpret-802-11ac-datarates/ta-p/3151995
Dont forget to rate helpful posts
Sandeep Choudhary
or
More info:
You can also look at the new Monitoring portion and look at Client Performance or Clients. There is a Connection Rate table. I was looking for more of a report. I was able to get exactly what I was looking for by filtering on the protocol and putting ac in the filter.
