Assosiation problem with AP1100 and Xsupplicant using EAP/EAPoL
Felix2
Hello All,
after trying couple of things to solve my problem and
being unsuccess, I wanted to get an oppinion of an expert
to solve my problem.
The problem is following: I am having a Cisco AP 1100
and a Cisco WLAN PCMCIA card PCM352. I wanted to set up
a 802.1x authentication scenario with them. I am trying
with RADIUS server as authentication server and xsupplicant
at client side. The thing is, I am checking for the respective
Accesspoint and assosiating with it to communicate and
starting xsupplicant with 802.1x process.
As soon as I get assosiated AP is sending me a Request.
Now Xsupplicant is starting EAPoL to which AP is sending
again a Request, to which the Xsupplicant is sending an
answer. But the AP is telling that the Response ID is not
matching with the Request ID.
Question: How can I tell to AP that it should ONLY send
a request if EAPoL Start is sent and not, if I just insert
my card into the PCMCIA slot.
I would be happy if you can help me in this point, as I
am not able to solve this since couple of days.
Thanking you in advance
scottmac
Level 10
Level 10
Did you install the proper certificate at the client side?
-Scott
Hi Scott,
I have installed all the required credentials. I have observed following. If I insert a WLAN PCMCIA card, I am getting every 30s a Request from Cisco AP. If I give a response to this request, I am able to assosiate with the AP and getting success from RADIUS server. But if I start the 802.1x scenario, i.e. starting with EAPoL start request from client, sometimes it is working and some times not. After debugging the traffic, I found that AP is getting confused between the request he sends every 30s and the request he send after getting EAPoL start. That seems to be problem, for which the Cisco-Firmware should find a solution.
I mean there should be an option in the AP configuration to send request only in response to EAPoL start.
Thanx,
Felix
