Showing results forĀ
Search instead forĀ
Did you mean:Ā
Audio Sonos / WLC 3850
We have a AUDIO SONOS equipment connected to the VLAN14, which we should control from the VLANS 11 and 12.
Vlan 11 and 12 are wifi using the WLC 3850, do you know if i have to configure something in the wlc to work?
The routing between vlans is ok.
Best regards.
Leo Laohoo
I haven't used SONOS before but I believe Bose (and probably SONOS too) are using mDNS.
I had to enable the multicast options in the wlc and in the router ip pim dense-mode and global ip multicast-routing and it started to work.
Best regards.
