Audit Wireless LAN controller
bhunt7
Visitor
I'm trying to audit approx 300 WLC's using Prime. I would like to have prime verify the Radius servers configured on all the WLC's Prime manages. Can this be done with a report, audit tool, compliance tool?
Scott Fella
This can be done with the compliance feature. With compliance, you need to have the high end install which is the pro. Now you might be able to run a cli template that will how you your radius servers and then grep that or possible run other automation like Ansible to get that output.
-Scott
