Authentication between Subordinate AP and Controller
shehrozceh
Hi Experts, i have one query regarding security point of view that there is any authentication process for subordinate access point to be joined with mobility express controller.
Let suppose, i'm plugin the Cisco AIR-2802i AP with the network and trying to join the ME controller with the simple command, 'capwap ap primary-base <controller name> <controller ip> but what i want to authenticate before joining the controller like any authentication key between capwap AP and ME controller.
pieterh
look at this post  where I read this is not possible.
what you can do is authenticate the accesspoint at the port-level where the accesspoint is connected to your network.
The same post contains some info on that.
