How can I ensure only known AP's connect to WLC
richard.dimond
I have a Cisco 2112 WLC with 1131 LWAP's
How can I ensure only known AP's connect to the WLC?
Thanks in advance
Richard
Hi Richard,
You can use the Authorize AP's against AAA function to make sure that all the AP's registering to your WLC are authorized AP's of the network.
By enabling this feature, only those AP's whose mac-addresses are present in the authorization list, will be able to register to the WLC.
This authorization list can either be present externally on a server or a local list on the WLC itself. The link below explains it in detail:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00808c7234.shtml
Another feature, that has already been mentioned in this thread, is Rogue detection. Using this feature, the WLC will be able to detect any AP that is not a part of its RF group and contain it.
Please refer to the document below for more information regarding this:
https://www.cisco.com/application/pdf/paws/70987/rogue_detect.pdf
Maithri
8 Replies 8
Surendra BG
Hi Richard,
You can prime the AP by prividing the Management ip to join and the other way is to maitain the APs by using the Rogue rules..
Here is the link to do the same..
Priming the AP
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a00808e2d27.shtml
Rogue Rules
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70rrm.html#wp1180349
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
Leo Laohoo
Can you elaborate further by the statement "known AP's connect to WLC"?
Cisco APs, running the correct IOS, can join a WLC.  Another hurdle is the port.  It has to be in the correct VLAN and should be an access port.
If you have, say, a NetGear AP then there's a snowball's-chance-in-he11 it'll join the WLC.
George Stefanick
On larger deployments or if you have a ACS you can go security --> ap polices --> AP authorize against AAA.
richard.dimond
Elaborating further .....
I am ensuring that my wireless network will pass the PCI data security Standards.
If somebody else connects a Cisco 1131 Ap into the network it will be seen by the 2112 WLC and be able to be connected to.
If the malicious person with this access point was using a console cable, could they not arrange to capture packets or disrupt the network in some way?
I would like to be able to ensure that this possible rougue Ap would only be able to function within the network after correct configuration via the WLC.
Richard
Hi Richard,
Maithri
The local AP policy list is just what I needed.
Just one more thing
When I plug my "Rogue" AP into the controller I expected it to be reported on the monitor as a "rogue on wired network" but I do not see this "rogue" showing up in any of the lists.
Just see
0Wed Feb 9 12:19:45 2011Failed to authorize AP with Base Radio MAC 00:3a:99:67:69:60. Authorization entry does not exist in AAA server.
1Wed Feb 9 12:19:45 2011AAA Authentication Failure for UserName:e05fb9ea5f54 User Type: WLAN USER
Richard
Hi Richard,
Do you have any APs in "Rogue Detection"  mode sitting on the trunk port on the switch?? if this is present then  only, this AP will detetc the Rogue on Wired.
Surendra
Surendra BG
Sur 5+
Everyone always forgets the "trunk" for Rouge Monitor APs...
