Auto clients disconneting
rasha.k.satu
Visitor
Hi All,
I am trying to find away to automatically disconnect client from APS when they are not using it, is there a way to do this in Meraki?
@rasha.k.satu : there is no timeout option. The session will only terminate once the user clicks disconnect
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
WB2
Level 3
Level 3
Guessing you're looking for a user idle timeout value that you can set, I don't believe Meraki has this option available but support might have a sneaky setting that can be enabled by asking?
Yes that's right,I will check with the support, Thank you.
