Auto RF Problems
udom_boon
Frequent Visitor
Frequent Visitor
Hi Guys,
I have problem for Auto RF.I have environment with 40 AP 1131AG,WLC 4402-50AP using 4.2.130.
Problem:AP no Auto Power the controller set Level power to Maximum. AP to AP interval 10 m of no obstruction.
I config Auto RF by Default
Can you help me to explain the problem
Scott Fella
Depending where the ap's are placed and how many ap's can be heard at a given ap location, RRM adjusts the power of the access points only when an access point sees the 3rd neighbor at -65 dbm or greater. It is possible that the 3rd ap signal is not strong enough to trigger RRM TX power.
http://www.cisco.com/en/US/customer/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml#tpca
-Scott
Fella5 is correct, I just want to point out however in your environment it would be -70dbm or greater because of the code you're running.
