Guest Access WLC Help
jonathan.roberts
Community Member
I have 2 WLc 4402. 1 Remote and 1 DMZ. I have read the deployment guide for guest access 20 times and still cannot get it to work. a couple answers that I don't see in the guide. 1. Do AP's need to be associated with the DMZ WLC? 2. Am I anchoring my management IP or a different Dynamic IP? I have verified with Eping and mping that the tunnels should be able to be created, how do I verify? An issue that concerns me is that I cannot ping (ICMP) my remote WLC mgmt interface from the DMZ WLC. I know I have connectivity because of eping, mping and https mgmt from the same subnet as the DMZ WLC MGMT Interface. should I be concerned about this? It could just be ICMP blocked at the FW.
I am trying no to open a support ticket as I am sure this is a simple issue. One of my problems is that my VLANs cannot be tagged because the DMZ VLAN does not reside on our core switches and hence I cannot do 802.1Q which is discussed on page 4 of the dep. guide. to get around this I configured IF/2 on my Remote WLC to an IP from my DMZ subnet? Is this ok, is it needed?
Summary Internal IF 1.1.1.1 for both WLC
remote WLC
MGMT = 10.160.24.30 IF/1
AP-MGMT = 10.160.24.31
Service = 192.168.0.10
guest = 10.160.80.16 IF/2
DMZ WLC
MGMT = 10.160.80.15
ap-mgmt = 10.160.24.33 (don't need?)
service = 192.168.0.10
internet = public IP to be natd by FW
I am a newbie to the Cisco WIFI world, but not to IT/networking.
Any help would be greatly appreciative
tekjansen101
I believe you need to enable IP Protocol 1 (for ICMP) in order for ping to work ...
weterry
Level 10
Level 10
a) No
a) No IP gets anchored. You Anchor the WLAN on one controller to your DMZ. On the DMZ, you anchor that wlan to itself.
3) I have verified with Eping and mping that the tunnels should be able to be created, how do I verify?
a) from CLI: show mobility summary
This will should you if everything is UP, or if control/data path is down. EPING/MPING should verify this as well if they are successful.
I'm not sure what you mean about port 2. Are you placing a link straight out to your DMZ? Normally everything goes out the main interface and "routes" out to your dmz.
yueric
Community Member
I had the same issue about guest DMZ controller , do I need to config same SSID on both of anchor and foreign controller ? I also need to use web-auth for wireless guest , which controller's SSID need to be configured web-auth ? By the way , I found a example on CCO , but only for "wired" ,
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808ed026.shtml
anyone can provide me the example for "wireless gest tunneling " will be very appreciated.
yueric,
1.do I need to config same SSID on both of anchor and foreign controller?
-Yes the wlan needs to be configured the exact same way on both the anchor and foreign controllers
2.which controller's SSID need to be configured web-auth?
-Both need to be configured the same way, so if you want to use web-auth you need to configure the anchor and foreign controller wlan to use web-auth.
