Autonomous 2606i for 802.11n
josephschung
Sir,
I have the 2606i configured with both radio 0(2.4GHz) and 1(5GHz)  up. They are working. Both radioes should support N. But when I connect my laptop to it, the laptop is connectiong to one of the radio only and with bandwidth 54M only.
How can I configure the AP to achieve 450M as mentioned on the datasheet?
Is there any special command needed?
I attached the show version result for you to verify the HW.
Thank you.
Scott Fella
You need to make sure your client device is 802.11n supported. With 802.11n you need to either use an open SSID or WPA2/AES. Also on the 5ghz, enable 40mhz channel width.
-Scott
Scott Fella
-Scott
Thank you Scott. The WPA2 make it 450M now.
Thanks for the follow up!
-Scott
Scott Fella
Here is a link for another model AP but still relevant.
http://www.cisco.com/en/US/docs/wireless/access_point/1140/autonomous/getting_started/guide/ap1140aut_getstart.html#wp43650
-Scott
