Cisco Aironet 1250 help
josh.hamrick
So I figure I got an incorrect or corrupt IOS.  I tried to perform the mode reset, but it starts to transfer and then errors out.  Here's an example of what the output is at, and it just sticks here:
IOS Bootloader - Starting system.
Xmodem file system is available.
flashfs[0]: 150 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31868928
flashfs[0]: Bytes used: 7369728
flashfs[0]: Bytes available: 24499200
flashfs[0]: flashfs fsck took 19 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 00:22:90:5d:4a:6a
button is pressed, wait for button to be released...
button pressed for 45 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/c1250-k9w7-tar.default
examining image...
extracting info (286 bytes)
Image info:
    Version Suffix: k9w7-.124-25d.JA1
    Image Name: c1250-k9w7-mx.124-25d.JA1
    Version Directory: c1250-k9w7-mx.124-25d.JA1
    Ios Image Size: 5765632
    Total Image Size: 6533632
    Image Feature: WIRELESS LAN
    Image Family: C1250
    Wireless Switch Management Version: 7.0.94.21
Extracting files...
ERROR: Problem extracting files from archive.Loading "flash:/c1200-k9w7-mx.123-8.JEE/c1200-k9w7-mx.123-8.JEE"...###########################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1200-k9w7-mx.123-8.JEE/c1200-k9w7-mx.123-8.JEE" uncompressed and installed, entry point: 0x3000
executing...
So as you can see above, I tried to load another image in this output, but it starts uploading, then gives "
ERROR: Problem extracting files from archive.Loading "flash:/c1200-k9w7-mx.123-8.JEE/c1200-k9w7-mx.123-8.JEE"  and continues with the same IOS, which sticks for hours at executing with no sign of failing.  So I am unable to get a new image in it, and the one loaded appears to just stick.  Any idea how to get around this?
Scott Fella
You have the wrong image. The one you have is for a 1200.
This is what you need.
c1250-k9w7-tar.152-2.JA1.tar
-Scott
First off, thank you much for the response.  I came to this same conclusion not long after posting the topic.  I got it off ebay, probably not the best place to get eletronics, but haven't gotten burned (till now).
The problem is, I can't "break" it like a normal router to get into rommon.  Every time it tries to decompress the incorrect IOS and freezes at executing...  I have tried to do the TFTP mode solution, but it starts transferring then gives this error:
ERROR: Problem extracting files from archive.I suspect perhaps not enough space?
Though from the flash output, I don't think that's the problem.  I know I am using the TFTP solution correctly, I have used it with routers and switches with no issues in the past (it's pretty hard to mess that up anyhow).  I've been looking all over google for anyone with a similar issue, and have been unable to find anything..
I do appreciate your time, and let me know if you have any insight on how to fix this.
