Showing results forĀ
Search instead forĀ
Did you mean:Ā
Autonomous Configuration by using Cisco Mobility Express
oshaka321
Frequent Visitor
Frequent Visitor
Hi Guys
I've got an cisco 1852 AP. Its model is AIR-AP1852ISK9C-RF. The Cisco Mobility Express software has already installed on that AP. I will use this AP for a wireless site survey. In order to do that, I should configure it as a standalone AP. If it is highly appreciated if you can explain me how to configure standalone settings for this AP by using Mobility Express. Many thanks.
Cheers
Oshaka
Rasika Nayanajith
I would go with 8.5.120.0 , if it comes with earlier releases.
Follow below URL for how to configure it for sitesurvey
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-5/b_cisco_mobility_express_8_5/b_cisco_mobility_express_8_5_chapter_0100.html
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Thank you very much for your support.
Not a problem.
If you able to configure it using provided link, you can mark it as accepted solution.
Otherwise pls let us know any queries.
Rasika
