06-14-2018 05:01 PM - edited 07-05-2021 08:44 AM
Hi experts,
I was checking the AIR-ANT2544V4M-R for a warehouse and in the datasheet, there are these caracteristics that I don't really understand :
Azimuth plane (3 dB beamwidth) : omnidirectional
Elevation plane (3 dB beamwidth) 2.4 GHz band : 60 degrees
Elevation plane(3 dB beamwidth) 5 GHz band : 33 degrees
I don't really get this ...
Solved! Go to Solution.
06-16-2018 07:29 PM
06-14-2018 10:16 PM
06-16-2018 05:43 PM
Hi Leo,
I understand the difference between azimuth and elevation, but in the example given (antenna 2544), what's the difference between the 33 and 60 degrees ?
Thank you
06-16-2018 07:29 PM
06-17-2018 03:30 AM
Thank you very much Leo ! That's clear now ! :-)
