B1400 non-root does not display/monitor temperature
jcowtan
I have root and non-root B1410 bridges. The root bridges will show temperatures in the GUI. The non-root do not. They show a WARNING: No Reading temperature monitoring is at 'INITIALIZE' state. What does this mean? I have not been able to find any reference. Other than root/non-root parms, I see nothing that is different in these configurations. They are in remote locations and temperature reporting is needed.
6 Replies 6
kka
Level 5
Level 5
What IOS version are you running?
I've seen this on several BR1310. Upgrading to IOS 12.3(7)JA2 fixed this.
We are running 12.3(7)JA2 on all bridges.
I am seeing this also. Did you ever get an answer to this. Possible Bug ??. I'm running 12.3(7)JA2
on a 1400as well. Root displays correctly, non-root does not.
-pat
No. I have received no further detail on this item.
Thanks for the response. After some digging I found this BUG.
It says fixed in 12.3(8)JA
BUT I CANNOT FIND 12.3(8)JA for the 1400....
BUG ID: CSCsb63034
Bug Details
Headline show env No Reading Temperature monitoring is at INITIALIZE non-root
Product br1410
Feature OTHERS Duplicate of
Severity 3 Severity help Status Verified Status help
First Found-in Version 12.3(4)JA First Fixed-in Version 12.3(8)JA Version help
Release Notes
Symptom:
Non-root bridge running 12.3.4.JA & greater 'show env' output sometimes shows:
Environmental Statistics
Environmental status as of 09:47:18 S Aug 8 2005
Data is 55 second(s) old, refresh in 5 second(s)
No Reading temperature is at 0 (C)
Workaround:
None but this appears to be cosmetic.
-pat
12.3(8)JA The finally showed up under the 1400 but no release notes. I opened a case and found out that in approx 3 days, 12.3(8)JA1 will be out WITH release notes. MAYBE THIS ONE WILL WORK RIGHT....
But i'm sure it won't be the end...
