backup interface problem
Lavanholy
Level 4
Level 4
I have a Cisco 2811 router,which has 2 fastethernet ports ,WIC-1T card.
1. WIC-1T is connected to teh ISP by means of 128KB leased line.
2. Fastethernet 0 is configured with Public STatic IP and connected to a switch,where 5 usres are connected with public IP.
3. Then the second fastethernet 1 interface is connected to a ADSL modem provided by the same ISP.
Now I want to configure this fastethernet 1 as the backup interface for teh Serial interface.
Please guide me how to achieve this.
Thanks and Regards,
S.Venkataraman
Not applicable
Why do you want to configure your fast ethernet interface as the backup interface to the serial interface?? Normally only a serial interface should be used to act as a back up for another serial interface. You cannot configure a fast ethernet interface as a backup for serial interface.
Hi Joas,
Thanks for your info.I have completed day before yesterday.It is working fine.I have 2 Fastethernet and 1 WIC-1T,The WIC-1T is connected to ISP.
F0/1 is assigned as the global public IP and it is attached to the PROXY server's one of the NIC which is also assigned as the Global Public IP.
F0/0 is defined as the backup interface for the Serial interface,F0/0 is private IP to which LAN interface of the ADSL is attached whose IP also in the same subnet IP of F0/0.
Now whenever the serial interface is down teh fastethernet 0/0 is coming up and we are able to access the Internet.
Thanks a lot.
Best Regards,
S.Venkataraman.
