Bandwidth Management using 5508
mumbles202
Level 7
Level 7
I setup a WLC5508 with 2 SSIDs, one for guest traffic and another for internal users.  They are in separate subnets and are routed out to the internet via 2 different isps, with the guest network going over a bonded t1 and the internal users going out the primary internet connection for the company.  While this works as desired and we've verified that while on the guest network we're going out the right isp, we've encountered an issue with saturation of the bonded t1 pipe by guests.  We'd like to find a way to limit a guest to a capped down/up stream if possible, with downstream being the most important.  The infrastructure includes 3560 switches and AIR-CAP3502I-A-K9 access points.
Stephen Rodriguez
You can do bandwidth limiting on the WLC but currently it is only downstream from the WLC.
What you'll want to do is enable rate limiting from the edge in on the guest subnet. This will give you the greatest control of your bandwidth on the network
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
