Best options for wireless security
wafflemachine
Community Member
I have an Aironet 1040 access device, no controller. I have an LDAP server with radius in front to allow for username and password authentication(using MS CHAPv2) with mandatory WEP and PEAP.
I was wondering what the strongest security option is that allows me to retain the username and password authentication. The current setup functions but leaves much to be desired.
Scott Fella
Use WPA2/AES with Mschapv2 and PEAP. No need for wep
-Scott
ill just add. Make sure you use somethin other then your ID for the outter ID becuase this is sent in the clear and can be sniffed. To prevent a man in the middle I would also vaidlate the certificate with PEAP.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
