Best Practices - Antenna Placement
Chris Pohlad-Thomas
We have 3 3602Es connected to a 2504 WLC. I was wondering if anyone has advice or a site they can send me with best practices for antenna placement. They are all mounted on the side of a wall, near the ceiling (above everyone's head).
Thanks!
Take a donut and put the antenna through the hole in the middle... its like that.  So you will get more vertical coverage than horizontal if the antenna is parallel to the ground.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
10 Replies 10
George Stefanick
What model antennas ?
According to one of the ziplocs it looks like they are:
AIR-ANT2524DW-R
Chris,
Stepping back to RF fundamentals, it tells us dipoles are like circle donuts see the attached. So depending how you arrange the antenna placement you will favor one side or the other.
Case in point if they are installed on the side wall and pointing hoizontaly  then you can see you are wasting part of your coverage above and below and not some much left or right.
Cisco recommends dipoles be installed vertically often to ceiling tile for optimal performance.
Hope this helps
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
As a matter of fact, I think we do have the antennas parallel to the ground. So, how does one determine which sides of the antenna the radiation is emitted from? Is it from either flat side?
Honestly it doesn't really matter.  If you have the antenna Vertically the energy is going to spread out.  But yes it should be from the flatter sides.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Flat side or pointed side does not matter.... the radiation pattern will be as what George has shown above.
Scott
-Scott
I guess my other question is, what is the determining factor of which side of the axis that the signal is radiated to? This may sound dumb, but for example looking at the image above, we can see the radiated pattern is both above and below the axis, but what about coming towards you (if you were looking at the antenna) or radiating away from you from the antenna?
Scott
-Scott
To add to Scotts comment. The HIGHER dBi the antenna the more longated the coverage becomes.
Wow, that is probably one of the easiest to understand answers yet. So if the antenna is perpendicular to the floor and the AP is flat against the wall then theoretically you are only losing maybe 25% of your power to the wall behind the AP. With it parallel you are losing probably 50%.
