Best practices on channel selection for APs
gjuinio
Should I trust AP1200 series least congested channel selection feature (of course only highlighting 1,6,11 to select from)?
wdrootz
Level 4
Level 4
The least congested channel setting will work fine. The AP will automatically scan the channels and select the least cogested channel.
djoconnor
It depends on your preference to some degree. I prefer to set them manually after looking at the current spectrum being used.
