best practises for MR installation
Greg Goudou
Community Member
Hi everyone,
I would like to know if you have a document that informs about how we have to install an access point : what kind of wall? what kind of drilling ?
Everything that can help us to install MR in order to enjoy the best performance
aleabrahao
Meraki Community All-Star
Look at this:
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/Best_Practice_Design_-_MR_Wireless/High_Density_Wi-Fi_Deployments
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
5 Replies 5
aleabrahao
Look at this:
thank you for the answer. It is very interesting. Regards
BlakeRichardson
If you are totally new to deploying wireless maybe seek the advice of a consultant this time around so that next time you know what to look out for.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Philip D'Ath
If you Google "Meraki MRxx Installation Guide", where "xx" is the model you are using, you'll get detailed instructions.
For example, the MR36:
https://documentation.meraki.com/MR/MR_Installation_Guides/MR36_Installation_Guide
Thank you. I will use the information with those provided by @alessandrodematos
