03-21-2018 04:10 AM
Just FYI I'm from a cloudtrax/openemesh background
Also I have only 1 unit to trial so may not have the full picture.
We have 20+ construction sites.
Each site has 3 unique SSIDS - ClientXXX, StaffXXX, GuestXXX
XXX is a unique identifier for the site.
A 4th SSIS is common to them all - Tech but is hidden
I cannot see a way to replicate this in Meraki
It looks like we're restricted to 15 SSIDs.
I've created 2 networks but the SSID options remain the same regardless which network I choose.
Am I correct in my understanding and we're limited to 15 SSIDs for the organisation?
Can this be increased - I don't need 15 SSIDS per location, but I need more than 15 SSID company wide.
Solved! Go to Solution.
03-21-2018 05:03 AM
15 SSIDs per network. you should be able to editt/create them for each network.
Did you maybe clone the network or attach it to a template that sets the ssid?
03-21-2018 05:03 AM
03-21-2018 05:23 AM
Genius! - You are a Star
03-21-2018 05:21 AM
This may suit your organisational/network structure.
03-22-2018 06:59 AM
So: yes, one Network per site... Not just because you then get 15 SSIDs for each site, but also:
A Network can only be in one time zone - if you have lots of APs in different countries, you will probably want accurate local time for each.
If you ever want to deploy the MX Security / VPN / SD-WAN appliance, you can only have one MX active in any single Network in Dashboard. (MR + MX and maybe MS switches too, all together, then suggests use of Combined Networks, per site, as @Uberseehandel mentioned)
