best product for wifi configuration
Stefano3
I'm new to the networks.
I need to set up a network to connect my PC to its data acquisition device (usually connected via LAN, static IP).
PC is 200 m far from daq device. Between daq device and PC there are several metal structures. I have already tried with industrial wifi but signal is too weak and PC can't see daq device.
I think i need a Repeater and I was looking for Aironet 1540.
Can i use it as access point, near my pc, as client, near daq device and as Repeater somewhere in bewteen ?
If it isn't enough can i add in series another repeater ?
Thank's
balaji.bandi
You can try extending the signal, this not give 100% results, better is site survey (but cost bit) - instead you can try with External AP like Aironet 1540. should able to work.
Not sure how far signal can boost based on the metal structure.
BB
Leo Laohoo
It is called Point-to-Point Wireless Bridge.
And here is the kicker:
The P2P Bridge will work if there a WLC.  Unfortunately, Cisco's documentation about P2P wireless bridge is hopelessly incomplete and incorrect.
