Big area covering - Wireless 802.11g
aamaral
What is the better solution to coverege a circular area with 4 miles (6 km) of diameter? (with 802.11g) TIA
scottmac
Level 10
Level 10
Depending on your anticipated traffic loads, a high-gain omni in the center with directionals on the periphery aimed at the omni usually works pretty well.
If you are anticipating heavy traffic from each/all peripheral locations, then you may want to go with several APs at the center, each with a directional antenna toward the remote it will serve.
If you are trying to cover a large area for clients (i.e. WISP) then you're looking at a large matrix of APs ala cellular ... conencted either by cabling, or an RF backbone (like the 15000 series ... 802.11b to the clients, 802.11a forms a mesh backbone).
Some details would help.
Let us know
Scott
Do you know where can I find information about AP1500 series area covering ? Once more TKS !
Here's the link from the Main Cisco Site (http:// www.cisco.com , front page, near the bottom):
http://www.cisco.com/en/US/products/ps6548/index.html
Good Luck
Scott
