blinking lights?
warner
Visitor
Is it possible to make the LED on an access point blink for ID purposes through CPI? We are running 3.2, if that makes a difference.  I can see how to do it from the WLC, but I was hoping there was a way that would not mean giving out WLC access to a fleet of technicians. I suspect I'm out of luck, but maybe I'm missing something. Thanks.
 Could you elaborate?
 What you mean by CPI ? Did you mean API?
 And which version is 3.2?
 The idea of less besides AP status is identify the AP, no big deal.
-If I helped you somehow, please, rate it as useful.-
CPI is Cisco Prime Infrastructure. It's Cisco's management platform.
Leo Laohoo
Not possible.
Sandeep Choudhary
If I undersatnd your question clearly then yes You can do it with Prime 3.2:
Go to Configurations > Templates > Lightweight Access Points
Here create a Template and make sure to check the box for AP LED status.
example in pic:LED.png
Dont forget to rate helpful posts
