Block hosts to communicates
omar_elmohri
Level 3
Level 3
anyone can help me find the command to use to deny any host to communicate with an other connected at the same access point?
I have a 1231 Aironet AP.
Omar,
jolmo
Level 9
Level 9
Hi Omar
under "interface Dot11Radio0" use:
bridge-group 1 port-protected
For more info:http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_guide_chapter09186a00801d0179.html#wp1038494
Hope this helps
jolmo
Level 9
Level 9
Hi Omar
Hope this helps
scottmac
Level 11
Level 11
In the WebGUI, under the radio config, there's a checkbox labeled "Public Secure Packet Forwarding (PSPF) ... checking that (enabling it) will prevent a client of the access point from accessing another client on the same access point.
Good Luck
Scott
