Blocking users after migrating from WCS to NCS?
Jason Aarons
Level 6
Level 6
One of our people in our Helpdesk  blocked a user mac because of an alert that said they were using the WiFi in an unsafe manner.  Probably streaming or file sharing.  Anyway when they blocked the mac they noticed that in the older WCS it would ask if you want to block this on all controllers.  The new NCS he said did not have that option that he could find.  So the user just authenticated with the same machine to a new controller which then had to be manually blocked.
I could not find in NCS the option to block the offending mac on all controllers either.  This does not mean it isn’t there?  Can we get a ruling on this? Bug? it worked in WCS.
Scott Fella
What version of NCS?
-Scott
Went from WCS 7.0.230 to NCS 1.1.1.24
I would have to test that later. I have both setup so we shall see.
-Scott
Eric Lindsey
We have NCS 1.1.0.58 and I believe when we block the Mac from NCS it only blocks if on the controller that it is currently associated to.
