BOM
wilmergomez495429572
Community Member
Bill Of Material (BOM)
I need a Bill Of Material (BOM) for the Main Part Number = AP9105    Internal
Since the former Cisco Aironet 1830 series has come to the end of Sale
Would you please help me with the BOM. I will add them to a 5520 WLC.
By now the current AP licenses in the WLC are 200 and the connected ones are 113.
Thanks in advance,
Wil Gomez
balaji.bandi
suggest to contact Local partner, so it easy to calculate requirement and quote.
BB
Arshad Safrulla
Ceiling Mounted
C9105AXI-E Cisco Catalyst 9105AX Series
NETWORK-PNP-LIC Network Plug-n-Play Connect for zero-touch device deployment
AIR-AP-T-RAIL-R Ceiling Grid Clip for APs & Cellular Gateways-Recessed
AIR-AP-BRACKET-8 AP Mounting Bracket
SW9105AXI-CW-K9 Capwap software for Catalyst 9105AXI
CDNA-E-C9105 Wireless Cisco DNA  On-Prem Essentials, 9105 Tracking
AIR-DNA-E Wireless Cisco DNA On-Prem Essential, Term Lic
PI-LFAS-AP-T Prime AP Term Licenses
AIR-DNA-E-T Wireless Cisco DNA On-Prem Essential, Term, Tracker Lic
AIR-DNA-NWSTACK-E AIR CISCO DNA Perpetual Network Stack
Wall Mounted
C9105AXW-E Cisco Catalyst 9105AX Series-Wallplate
AIR-AP-BRACKET-W4 AP Low Profile Mounting Bracket
SW9105AX-CAPWAP-K9 Capwap software for Catalyst 9105AX
CON-SNTP-C9105AIE SNTC-24X7X4 Cisco Catalyst 9105AX Series
CON-SNTP-C9105AWE SNTC-24X7X4 Cisco Catalyst 9105AX Series-Wallplate
For the above I used DNA/Network Essentials licenses, since you will be connecting to a 5520 you really dont need DNA licenses, but recommended to have it as you will be soon migrating to Catalyst (migration is inevitable as 5520 is already announced EOL/EOS)
Below is the BOM without DNA sub
CON-SSSNT-C9105AIE SOLN SUPP 8X5XNBD Cisco Catalyst 9105AX Series
C9105AXI-DNA-OPTOT CISCO DNA SUBSCRIPTION OPTOUT for C9105AX
CON-SSSNT-C9105AWE SOLN SUPP 8X5XNBD Cisco Catalyst 9105AX Series-Wallplate
C9105AXW-DNA-OPTOT CISCO DNA SUBSCRIPTION OPTOUT for C9105AXW
C9105AXW-SINGLE C9105AXW SINGLEPACK OPTION
C9105-OVER C9105AX OVER OPTION
Keep in mind you need to pay attention to the regulatory domain as well, above are ordered for E domain, so change urs accordingly. If you need different mounting kit for ceiling mounted AP you have the option of customizing that as well, so it is recommended that you reach out to a partner who has CCW access.
