Bonjour services over Wireless
Craig Le-Butt
Here is the scenario, a location has 10 rooms and each room has a apple TV box, the users only want 1 IOS device to work on 1 TV, so basically 10 IOS devices 10 TV,
Now the customer wants to be able to pick up the ipad unlock and connect directly to the 1 Apple TV.
I have snooping enabled on wireless, (8.0.210) so I am able to see the apple TVs, I was wondering if any one has come along any thing on this lines.
The Apple TV will be on wireless.
Running WLC 8.0.210 and ISE 2.0
cheers in advance
Ric Beeching
Level 7
Level 7
You could use AAA override with bonjour (mDNS) policies to restrict the advertising of each mDNS service to particular clients.
So connect it all up, discover the services via the WLC (it must be a centrally switched WLAN I believe) and then assign each Apple TV that is discovered to its own policy which can be applied to the individual iPads. You'll need mDNS snooping and AAA override enabled on your WLAN.
Ric
Please rate helpful / correct posts
