Booting Problems on WLAN controller 4400
banalas_2
Level 2
Level 2
I Got a new WLAN controller 4400 from out of the BOX from one of the vendor, its not booting completely its giving me the following error
PHY DEVICE : Found Intel LXT971A PHY at 0x01
FEC ETHERNET
IDE: Bus 0: OK
Device 0: not available
Device 1: not available
Booting Primary Image...
Press <ESC> now for additional boot options...
** Partition 4 not valid on device 0 **
** Unable to use ide 0:4 for fatload **
bzImage Image Integrity Check Failed(Bad Magic Number). Hanging
and its just sitting there, Please help trying to open a TAC case but i dont think it as smartnet
ankbhasi
Hi Friend,
This error generally indicates flash memory failure. I suspect you'll require hardware
replacement.
Ankur
