BR 1300 external antenna
jverkerke
Hi all,
I am planning to deploy point to multipoint bridges, at least 3 non-root bridges with ant-3338 directional dish antenna. Is it possible to install two directional antenna pointing in two different direction towards non-root bridges?
scottmac
Level 10
Level 10
No. Not unless both antennas are connected to the same (I mean the exact same) antenna terminal of your AP/bridge.
At best, you'd want to look at something like "sector" antennas to get the additional gain (like four 90 degree sector antennas to cover the 360 horizon).
Unfortunately, you'd also need some "power dividers" to accurately distribute the TX power and accurately combine the RX signals ... then the dividers will eat about half the gain (in some cases).
*Most* of the time, for point-to-multipoint, the "point" end (the root) should be an OMNI.
Good Luck
Scott
