BR1410 issues???
mscherting
Level 5
Level 5
Hi all,
I'm having some problems with a bridge shot between a pair of AIR-BR1410A-A-K9's, sometimes to the point that I can't get logged in (telnet) to the near root-bridge and users at the far end end up dead in the water. I have no trouble getting into the 2950 switch that the bridge is connected to. TACACS authentication to the bridge fails and sometimes falls back to local authentication as if the CPU is pegged.
The router LAN interface, switches, bridges and users are all one flat vlan1. I didn't design or build it. I just have to support it.
Root is running c1410-k9w7-mx.123-4.JA
Non-Root is running c1410-k9w7-mx.123-4.JA1
Current configuration : 229 bytes
interface Dot11Radio0
no ip address
no ip route-cache
ssid XXXXXXXXX
concatenation
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
rts threshold 4000
station-role non-root
infrastructure-client
end
Questions:
Ideas on things to check/eliminate?
How do I determine the noise floor if I wanted to use clear channel assessment?
Recommendations for a 5Ghz spectrum analyzer that won't break the bank (that I can sell to my boss)?.
Thanks!
b.hsu
Level 11
Level 11
Do you see any error message. If so post the error messgage
As I recall there were some messages about deauthenticating peer. The thing finally died to where I couldn't ping it from its switch. I'm on-site today after a six hour drive. I'll be replacing it today.
Thanks.
