Hi Folks,
I would like to bridge from an AP1131 to an AP1262 using the 5.8 ghz radios then allow access via the 2.4 ghz radio on the 1260. I will use a directional antenna for the 1260 bridge to optimize performance. The 5ghz radio will only be used for bridging. The ap 1131 is an AP right now but only offers access on 2.4 ghz. There are only a few clients.
The 1130 will be sitting in a window with the ant5160 outdoor mounted and pointed at it from ~200 feet away.
Does anyone see an issue? Maybe suggest a better parts list. I was originally thinking of using a 1310 as the bridge and a 1140 as the AP but that configuration is not as flexiable and the 1310 part is very old... I understand I will not get N throughput since the 1130 is not N capable, it is already installed. I need autonomous AP and can upgrade to 1140 in the future to improve performance.
I plan to upgrade to WCS next year, does it support this type of configuration? I am assuming that IOS does...
So here are the part numbers that I plan to use.
AIR-AP1262N-A-K9
AIR-AP1131AG-A-K9
Directional 5.8 ghz
AIR-ANT5160NP-R=
Omni 2.4 ghz
AIR-ANT2430V-R=
Thanks for any help,
Joe
