Bridge Connection problem
johnnys
Level 2
Level 2
I have a Cisco 350 Wireless bridges setup 18km apart.One is setup as Root and the other as NON-Root.
If I connect one machine, its works fine.As soon as
I connect more than one machine I loose connection
to the server on the headoffice side.
I have setup the bridge spacing for 18km.
I have checked for interfernce.
Has anyone had similar problems with these Cisco Bridges.
regds
Johnny
Not applicable
The connectivity problem may be caused by any of the following circumstances.
*Too much distance between bridges
*Radio frequency (RF) interference
*Misaligned antenna
*Bad cable
*Obstruction
Check this out:
http://cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350brdgs/brscg/br350ch9.htm
