Bridge Connection
Theo Van Wyk
Community Member
I have setup a RAP and MAP with AIR-CAP1602E-E-K9 all working fine.
I need to bridge the connection so that i can attach an switch on the MAP AP
Both AP's Ethernet connections are set to bridge but i cannot reach the switch on the MAP AP i can reach the MAP AP.
The MAP AP Ethernet set to trunk mode allowing VLANS transparent VLAN set to off, switches connections set to trunk mode on both AP's
current version WLC
7.4.110.0
think I am doing something wrong on the trunk link on the switch side
Upgrading to 7.5 actually fixed this issue. Luckily we haven't had any other issues because of upgrading for now
The bridge-group commands are still missing on Gi0 on the MAP, but as long as it is working I don't care.
5 Replies 5
Theo Van Wyk
Community Member
(Cisco Controller) >show mesh path Point_to_Point_Far
AP Name/Radio      Channel Rate Link-Snr Flags    State
Point_to_Point     36      auto 41       0x0      UPDATED NEIGH PARENT BEACON
Point_to_Point    is a Root AP.
Jochen Bartl
Frequent Visitor
Frequent Visitor
We've upgraded two days ago from 7.2 to 7.4.110.0. After that VLAN trunking wasn't working anymore. Like you described, I only could reach the MAP on the other side via the native VLAN.
RAP is a AIR-LAP1262N-E-K9
MAP is a AIR-CAP3502I-E-K9
After a bit debugging and logging in into the MAP via SSH I've seen that the bridge group config was missing on the APs ethernet interface. Adding the bridge group commands did fix the issue. However the commands don't survive a reboot of the AP.
interface GigabitEthernet0
bridge-group 1
bridge-group 1 spanning-disabled
no bridge-group 1 source-learning
So this is more some kind of a workaround. It would be interesting to know if you ran into the same issue.
Best regards,
Jochen
Hi Jochen
thanks for the reply, i got some info from our local cisco group that there is a bug in the 7.4 code giving issues with bridge mode but they have not done any testing to confirm. I wanted to upgrade the controller to 7.5 but client wanted connection up, so i used the following reference
http://www.cisco.com/en/US/customer/products/hw/modules/ps2797/products_configuration_example09186a0080bf450a.shtml?referring_site=smartnavRD. Standalone AP connecting to Mesh AP. The only difference is the AP is set to local mode on the controller.
wish i could test it now to confirm 🙂
Thanks for your reply Theo. We'll upgrade to 7.5 this evening. I'll post the results here after that.
