how to configure wireless air sap 1602?default ip adress?
kahilhassan
Hi does anybody know what is the default ip adress for to enter the configuration web page of the access point
air sap 1602?
how do i configure it?
I just plug it to my router and would like to configure it so it can be usable and recognised in my network
thanks
Scott Fella
Use a console cable and connect it to the AP. Default IP is 10.0.0.1 I believe unless it gets an IP address from dhcp.
-Scott
Rasika Nayanajith
Connect a console cable & get "show ip interface brief" output. That should tells you what is the IP assigned to your AP (BVI interface).
If your router gives DHCP & you just want to configure it for a SSID with pre-shared key, you can try some configuration like this.
hostname
dot11 ssid
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid
no shutdown
interface Dot11Radio1
ssid
no shutdown
interface BVI1
ip address dhcp
Rasika
**** Pls rate all useful responses *****
