Bridge Outdoor Calculation Utility
Nick Howells
When using the Bridge Outdoor Calculation Utility from Cisco i notice the cable drop down menu only includes the old STD type cables. Now Cisco have EOL'd the STD and 75ft cable, replaced with the LL cables, AIR-CABxxxLL-R products how does the calculations differ?
So far i have selected other cable and entered the dB loss from bottom of this URL:
http://www.cisco.com/warp/public/cc/pd/witc/ao340ap/prodlit/airoa_ds.htm
and then selected the length, 20 or 50 feet.
Anyone know if there are any plans to update this for the new cables or should i continue as detailed above?
Nick Howells Head of Solutions Sales - Collaboration STS (Structured Technology Services) T: 0116 240 8820 | D: 0116 240 8832 | M: 07764 710396 E: nickh@sts-communications.com | W: www.sts-communications.com
mmellet
Level 3
Level 3
You should use the tac feedback tool on the right pane of the utility (http://www.cisco.com/warp/public/102/wlan/faq-hardware-us-calc.html) and provide this feedback to tac. They'll probably contact you directly with your answer.
