Bridges Wireless - AP 1310
alrbatista
I'm setting up a Wireless Bridge 1310 with two APs. The Root Bridge is working fine, but the Non-root Bridge is not working, the radio 0 is not UP (It is in reset mode), bellow the settings of APs and logs Non-root Bridge.
AP Root Bridge
dot11 ssid BRIDGE-INTERSITE
   authentication open
   authentication key-management wpa
   guest-mode
   infrastructure-ssid
   wpa-psk ascii 7 **********
dot11 holdoff-time 3
dot11 ids eap attempts 300 period 60
dot11 network-map
dot11 arp-cache optional
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
speed  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 basic-48.0 54.0
channel 2462
station-role root bridge
rts threshold 4000
concatenation
bridge-group 1
bridge-group 1 spanning-disabled
AP Non-Root Bridge
   authentication open
   guest-mode
   infrastructure-ssid
dot11 network-map
no ip address
no ip route-cache
station-role non-root bridge
rts threshold 4000
concatenation
bridge-group 1
LOG (AP Non-Root Bridge)
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
%DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Response
%DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Rcvd response from "MAC ADDRESS" channel 11 2242
IOS Versio: c1310-k9w7-mx.124-10b.JDA2 for both APs.
Thanks.
Amjad Abdullah
No response in the logs could possibly indicate nonroot is not hearing the root.
What is the distance between the two bridges? Are they in line-of-sight to each other? Try to put them next. To each other and try. Make sure the preshared key is the same on both.
Rating useful replies is more useful than saying "Thank you"
Hi Amjad,
The distance is 500 meters.
Yes, are one in front of another.
The key is the same.
The APs are on top of two towers, we will remove the APs and the test on the ground.
Thanks.
Make sure to double checlk the cables connecting the Antennas to your Bridges if you have -R version of the 1310 bridges.
Your issue is very simple , non-root cannot detect the presence of the root ( no 802.11 frames advertising the same configured SSID ) --> Accordingly keeps scanning indefintely on all the channels of a certain band.
When selecting the channel on root make sure that it is clean as well on the non-root side to allow the non-root to connect properly wihtout having the info sent by root distorted due to noise , interference or any other RF impairments on certain channel. So you can run the carrier busy test many times on both sites and select the clarest channel to proceed with after making sure that everything else such LOS, HW status ......etc is ok.
