Bridging 1142 LWAPPs using a 2504 WLC
kerryjcox
I configured my 2504 to run the latest software and it works just fine with my 1142s running LWAPP. However, I want to run them in my home and there is no Ethernet cabling. Looking through all the Cisco pages I cannot find any reference to setting them in Bridging mode. I am probably just not looking in the right place. On some of the pages I found it states that the 1140s do not support bridging mode.
Can anyone set me right? Much appreciated.
2 Accepted Solutions
WGB is the term that you should search for and there is an excellent example here
You'd have to convert your APs to Autonomous mode first if you haven't done that yet
***Please rate all the useful posts***
-Prabath
Check this post to understand the WGB concept and how to config guide:
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/68472-configure-wgb-00.html
https://rscciew.wordpress.com/2014/08/15/wgb-with-multiple-vlan-in-uwns/
Don't forget to rate helpful posts
-Prabath
Ahh... I just got down converting them all to Lightweight mode as that worked fine for me before. I'll check the link and see what I can do.
Thank you very much for the response.
