Bridging AIR-AP1131AG with TP-Link
Totardo Tobing
Hi Guys,
Today I want to build a wireless bridge using AIR-AP1131AG (running WLC) and TP-LINK wireless router.
The result is failed. May I know AIR-AP1131AG is support bridging the wireless connection with other vendor's access point or not?
In the TP-Link I already match its SSID, Channel and put the mac-address of the AIR-AP1131AG.
In the WLC I already see too TP-LINK mac-address is already become a client.
So what's the problem guys?
Thanks Guys
2 Accepted Solutions
Scott Fella
Well bridging isn't supported when using a wlc, only workgroup bridge. So what your trying to accomplish will not work. You would have to convert the 1131 to autonomous, but you would need another Cisco device configured as a bridge on the other end. Or else you can leave the 1131 on the wlc and get a device that functions as a workgroup bridge or Ethernet converter. I have used the Buffalo Ethernet converters and the work just fine. You can use most of the the Cisco APs starting with the 1131 as WGBs also.
-Scott
That is correct... the WLC doesn't support PTP bridging unless it is mesh AP's. WGB's allow you extend the wireless to wired users. So you can take a 1131 autonomous ap and configure that as a WGB and that can connect to the LWAPP AP.
-Scott
6 Replies 6
Scott Fella
-Scott
Thank you for your explaination sir.
So are you saying that wireless bridging is only established when using:
{2 Cisco APs operating in autonomous mode} and { 1 Cisco AP is in lightweight mode and another 1 with workgroup bridge mode}?
Is that correct sir?
So bridge mode AP and workgroup bridge AP is a different mode sir?
-Scott
Okay, you are correcting me again sir.
So, If I want to make a workgroup bridge, I should take a 1131 autonomous AP and configure it as WGB and connect it to a LWAPP AP.
Thank you sir.
Hi air,
i got the same issue too, is that means
1. 1131 autonmous can linkup with WGB?
2. WCL with mesh ap's linkup with tplink?
i am a bit confuse of the second option, what means by mesh ap's?
is that only some of the specific ap model can be act as mesh ap?
MESH AP is only if you have a WLC and the AP's are in mesh mode.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_white_paper09186a0080b1c101.shtml
WGB connecting to a lightweight AP
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080905cea.shtml
-Scott
