Bridging Mode
Justin Ferello
Level 10
Level 10
Hello all,
I am new to Cisco wireless products, so forgive me for my newbie questions.
I currently have a Linksys WRT150N acting as my wireless core (I know, I cannot change it at the moment)
We recently took over a second floor in the building and we wanted to extend the Linksys signal, so we bought an AP1142N from Cisco to act as a bridge.
  1. Does the AP1142N only bridge with other Aironet products?
  2. If it can work with the Linksys, how would I configure it to the Linksys as I don't see much with regards to WPA2-Personal running AES?
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
under the ssid
dot11 ssid test
authentication open
authentication key-management wpa version 2
wpa-key ascii 0 < your key >
Dot11Radio {0 | 1}
encryption mode ciphers aes-ccm
ssid test
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
14 Replies 14
Stephen Rodriguez
If the AP is on a different floor, why 'extend/bridge'?
Just configure the 1142 to have the same SSID configs on both devices you should be fine.
HTH,
Steve
HTH,
Steve
Steve,
I am sorry, I actually have (2) 1142s that we are trying to configure.  The first one we want to use to extend the network.  The second one is being attached to a mobile TelePresence device (VX Clinical) and we need it to bridge the TP device to the WLAN.
For the first AP, I guess we could do that, then our PCs will just roam between the stronger signal, right?
Justin
Thank you,
Justin Ferello
For the first one you are correct.
For the second, you'll probably want to look into WGB mode.
HTH,
Steve
HTH,
Steve
Steve,
Thanks for advice.  We have been looking at the WBG but cannot figure out how to configure the AP to use WPA2-PSK & AES.  We see AES CCMP.
Justin
Thank you,
Justin Ferello
under the ssid
dot11 ssid test
authentication open
Dot11Radio {0 | 1}
ssid test
HTH,
Steve
HTH,
Steve
Steve,
Again, thank you so much for helping out.  Anyway I ran those commands and settings but its still not connecting.  Do I need to enable the antenna or something?  I did do station-role workgroup-bridge, is there a debug or log system?
Justin
Thank you,
Justin Ferello
can you post the config?  So long as the SSID matches, and it can 'hear' it from the network, it should be abel to join.
HTH,
Steve
HTH,
Steve
Steve,
Is that just 'show run'?
Thank you,
Justin Ferello
yes sir
HTH,
Steve
HTH,
Steve
Justin Ferello
Level 10
Level 10
ap#show run
Building configuration...
Current configuration : 1439 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$oXn5$UwYFs.rs55vEVD2wy0pkU0
no aaa new-model
dot11 syslog
dot11 ssid "KBZ Wireless"
   authentication open
   infrastructure-ssid
   wpa-psk ascii 7 113D382B33302E3E23
username Cisco password 7 00271A150754
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
ssid "KBZ Wireless"
antenna gain 0
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Thank you,
Justin Ferello
with a WGB, you shouldn't need the infrastructure command under the SSID.  You also need to do a no shut under the dot11radio 0 interface.
HTH,
Steve
HTH,
Steve
Steve,
How does one enter the SSID properly.
If I do:
ssid KBZ Wireless
Then I do not get the sub menus
If I do:
ssid "KBZ Wireless"
It looks like the AP is literally looking for "KBZ Wireless" instead of KBZ Wireless
Justin
Thank you,
Justin Ferello
I would remove the "KBZ Witeless". SSID and do it as KBZ_Wireless. White space in the middle like that can cause you issues. And the " is seen as a valid ASCII character
Steve
HTH,
Steve
Justin Ferello
Level 10
Level 10
Steve,
Thank you so much for the help, you were fantastic!!  I did the following:
Factory reset
Then type reset to get back to AP console
Then issued the following commands:
enable
Password of Cisco
configure terminal
interface dot11radio 0
ssid
authentication open
wpa-key ascii
exit
no shut
exit
exit
wr mem
Thank you,
Justin Ferello
